2001 Ford Mustang Poor Economy
SPARKY2007
I have a 2001 Mustang and it's getting poor fuel milage and I've sall ready completed a major tune up and that did not help. I have ran a code check on it and found four codes they are P0113, P0118, P1298 AND P1509, I checked all the items out and they test good so I'm stumped can any one help?
Sep 22, 2007 at 10:04 AM
MERLIN2021
  • 17,250 POSTS
P0113 Intake Air Temperature [IAT] Sensor Circuit High Voltage P0118 Engine Coolant Temperature [ECT] Sensor Circuit High Voltage P1298 Injector Driver Module Failure P1509 I need the engine code and the year code on the vin Most come up as IAC trouble All of these will cause poor fuel economy and performance, so they all can't be ckecking out OK! Temp sensor, have you replaced it? And does the car have a custom air intake? Thie intake plenum has 2 sensors on it the MAF and air temp sensor thats your 113 code, get back to me on the modification!
https://images.2carpros.com/forum/automotive_pictures/62217_CCRM_copy_1.jpg
If the CCRM is not sending power to the driver mod, you'll need to replace it!
Sep 22, 2007 at 10:30 AM
Suggested Repair
Recheck the IAT and ECT sensor circuits rather than assuming they are good, and inspect any custom intake affecting the MAF and air-temperature sensors. Treat P1509 as likely IAC trouble after confirming the VIN engine and year codes. For P1298, verify that the CCRM is supplying power to the injector driver module and replace the CCRM if it is not.
Conversation Summary
The owner of a 2001 Ford Mustang reported poor fuel economy and performance after a major tune-up. Codes P0113, P0118, P1298, and P1509 were present, but the owner said the related parts tested good. The expert explained that these faults can cause the symptoms, asked about temperature-sensor replacement and a custom intake, linked P1509 mostly to IAC trouble, and said the CCRM should be replaced if it is not powering the injector driver module.
