every 2 or 3 months I have to add a quart of oil to the engine. No smoke comes from the rear tail pipes and no oil stains on the floor/pavement where the car sits/park? replaced plugs no sign there of oil?
1996 Ford Mustang Oil Consumption
I forgot to ask, this is something that has always been the case? Or is it something that has recently become more noticable?
As far as oil consumption. I would guess it's normal. Check your PCV system as well. Sometimes the little oil drain hole in the valve cover becomes plugged allowing oil to be sucked into the vehicle intake. Makes the car run somewhat rough. It will actually suck quite a bit of oil.
Suggested Repair
Oil use of about one quart every 3,000–3,500 miles can be normal for an older 4.6 V8 as oil passes the rings and valve guides. Check the PCV system and the valve-cover oil drain hole for plugging that can pull oil into the intake. For outer wear on one front tire, check tire pressure and alignment, especially camber and toe, which can involve a tie rod.
Conversation Summary
The owner of a 1996 Ford Mustang GT 4.6 V8 adds about one quart of oil every 2–3 months, or roughly 3,000–3,500 miles, with no tailpipe smoke, ground stains, or oil on the plugs. The expert said Ford considers about one quart per 1,000 miles normal for older V8s and that oil typically passes worn rings and valve guides. The expert also advised checking the PCV system and valve-cover drain hole. Separately, outer tread wear on the front driver-side tire was attributed most likely to camber or toe alignment, or possibly low tire pressure.
