2000 Ford Mustang Window Off Track
LOTTATHOUGHT
I have a 2000 Mustang Convertible...standard 6cyl engine...
I have been trying to find info on fixing my driver's window and I am coming up totally empty.
I have searched all over for some info.
I have also looked and looked for for manuals on this car.
I have come up almost totally empty.
I am not some newbie to the internet..but this is ridiculous. I rarely have this much trouble finding information. It is not like this is some rare model of car.
My first and most pressing need is to fix the window. It appears to have fallen out of the track. I would LOVE to find some info on getting the door panel off and putting the window back into the track.
On a more longterm note, I would really like to know what manual people are using and what reference sources are available.
Any and all help is appreciated.
Jan 2, 2007 at 10:39 AM
MIKEYBDMAN
  • 623 POSTS
[quote:5675851710="lottathought"]I have a 2000 Mustang Convertible...standard 6cyl engine...
Any and all help is appreciated.[/quote:5675851710]
Ok, here is how to remove and install the door glass per the manual:
Door Window Glass
REMOVAL
Remove the door trim panel.
Remove the interior weatherstrip.
Remove the bolts and the stabilizers.
Remove the bolts and the upstop brackets.
Remove the rivet and the exterior weatherstrip.
Remove the rivets.
Tip the front of the glass down to clear the door filler and remove the door window glass.
INSTALLATION
To install, reverse the removal procedure.
I can send u some photos that make it make a little more sense if you message me with your home emaill address and I can mail them to you.
Jan 2, 2007 at 11:57 AM
Suggested Repair
Remove the door trim panel, interior weatherstrip, stabilizer bolts, upstop brackets, exterior weatherstrip rivet, and remaining rivets. Tip the front of the glass down to clear the door filler and remove it, then reinstall by reversing the procedure and reseating the glass in the track.
Conversation Summary
The owner of a 2000 Ford Mustang convertible with a 6-cylinder engine says the driver's window appears to have fallen out of the track and asks how to remove the door panel, reseat the glass, and find a service manual. An expert provides the manual removal and installation procedure for the door window glass.
