1996 Ford Mustang Wipers and Blinker
THAEMBASSY
I HAVE A 1996 FORD MUSTANG.. I NOTICED THAT THE WINDSHIELD WIPERS STOPPED WORKING.. THE ONLY WAY THEY COME ON IS IF I PUSH THE SIDE TO CLEAN THEM AND THEN THEY WIPE FOR THE THREE TIMES AND STOP. ALSO THE LEFT BLINKER IS BLINKING FASTER THAN THE RIGHT BLINKER.. I AM NOT SURE IF THIS I RELATED TO THE WIPER PROBLEM. ALL THE BULBS HAVE BEEN CHANGED.. COULD IT BE THE FLASHER SWITCH. AND FOR THE WIPERS COULD I CHANGE THE ARM ASSEMBLY?
Oct 25, 2006 at 2:45 PM
CATCH_15
  • 250 POSTS
If the wipers work when you go to clean the windsheild, you know that the motor is still good. That narrows it down to an electrical problem. Check your fuses under the dash and under the hood. Also, I wouldn't think a bad fuse would make one turn signal act up. Usuall when it blinks really fast, it means one of the filaments in the bulb is out and you need to replace the bulb.
Oct 26, 2006 at 4:24 AM
BRUCE HUNT
  • 3,754 POSTS
One of the bulbs is out.
The wiper problem is probably in the switch itself.
Oct 26, 2006 at 6:54 AM
Suggested Repair
Because the wipers run during the wash cycle, the motor is likely good. Check the under-dash and under-hood fuses, then suspect the wiper switch rather than the arm assembly. Recheck the turn-signal bulbs and sockets; a fast blink usually means a filament is out and is not typically related to the wipers.
Conversation Summary
A 1996 Ford Mustang owner reports that the windshield wipers only run for the wash cycle and that the left turn signal blinks faster than the right despite bulb replacement. Experts say the working wash cycle indicates a good wiper motor and point to fuses and the wiper switch. They also say the fast blinker usually means a bulb filament is out and is unlikely to be caused by the same fuse.
