2000 Ford Mustang Locks and Vents
JPRUETTING
2000 Roush Mustang, 78.8k miles, v6 3.8L.
Problems:
1. The power locks started acting weird a couple of months ago. They would maybe unlock the first time you hit the button, but if u continued to hit it, they would slowly "lose power" and move less and less each time until they would stop moving. Now, they hardly ever work. From what I have read, I think it might be a vacuum problem, but I don't know how to check it or how to find the leak if there is one.
2. The a/c and heat has not worked right since I got the car. It blows perfectly cold or hot, but it will only blow out the top vents or the floor vents. If I set it to floor, it still shuts off the top vents and vice versa, but it will never blow out the front vents.
3. One of the top left air vents on the dash is broken in half. It's a little oval plastic vent that is only a couple of inches wide. I have looked online and cannot find where to order a replacement. I tried looking for "air vent" and "dash vent".
Any help you can offer would be greatly appreciated. Thank you.
May 7, 2007 at 9:12 AM
MERLIN2021
  • 17,250 POSTS
There is a control unit for the locks...I think on the passenger kick panel. They are electric, not vacuum since the 70's. You must have a stuck door in the plenum or a disconnected vacuum hose.
May 8, 2007 at 2:39 AM
Suggested Repair
Power locks are electric, not vacuum; check the lock control unit, likely in the passenger kick panel. For HVAC that will not switch to the front vents, inspect for a stuck mode door in the plenum or a disconnected vacuum hose. The broken dash vent was not addressed.
Conversation Summary
The owner of a 2000 Roush Mustang with a 3.8L V6 reported power locks that gradually lose movement, climate control that blows only from the top or floor vents and never the front vents, and a broken small dash vent. The expert said the locks have been electric since the 1970s and pointed to a control unit on the passenger kick panel. For the airflow problem, the expert suggested a stuck door in the plenum or a disconnected vacuum hose.
