1995 Ford Mustang Lack of Power
WLBUNDI
  • 1995 FORD MUSTANG
Engine Performance problem
1995 Ford Mustang 6 cyl Front Wheel Drive Automatic
The catayltic converters were clogged so we have repaired that problem however now when I first take off there is a noticable lack of power but after I get going and it shifts then the car get going like it should.
Monday, July 26th, 2010 AT 4:11 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Monday, July 26th, 2010 AT 7:45 PM
