Disable the alarm system
RIVERMIKERAT
  • 6,110 POSTS
See if you can rent or borrow a scan tool and scan it for fault codes. I'm thinking that the anti theft unit needs to be in the loop to keep it running, but that the unit you have may be defective.
Thursday, March 9th, 2017 AT 2:04 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Try resetting the alarm by unlocking the drivers door from the outside.
Thanks for using the site :-)
BIGSWIG
  • 1997 FORD MUSTANG
Ok. Well. It isnt my car and im not 100% sure of exactly what happens. But ehre it is.
First off, the car starts and works just fine but it SEEMS random as to when it happens, sometimes when I go to get in the remote will not work to unlock the doors at all, and if I unlock the driver side door, the alarm goes off and disables teh ignition. So I cant restart it. I found a temporary fix: take off the red battery wire under the hood, get in the car, turn on the key (like the battery) then go reconnect the red wire and then start the car. But the key will not turn off the alarm by trying to start, or unlocking the door and the cremote doesnt work when the problem happens. It is NOT the key(chip) because ive went and got 3 new keys, and ive also replaced the remote battery and the car battery. Any ideas anyone? Again this is a 1998 Ford Cobra Mustang
NOS
  • 320 POSTS
This is a shot in the dark you say you have had new key's made. But have you checked to see if you need to have your keyless remotes reprogramed? Or you possibly have a short in the drivers door where the wires come from the cab to the door there is a rubber boot where your doorlock wiring and power window wiring and all goes through. Dude not even sure I can put you on the right track with this one.(NOS)? Sometimes the get out of sync
BIGSWIG
Ah yah ive programed the remotes, ill redo it maybe I screwed up, ill also check for a short, thanks for the suggestions
NOS
  • 320 POSTS
No problem not realy sure if I helped or not but I will keep an eye out for more updates on this one.(NOS)
BIGSWIG
Ehh ignore that I tried 2 keys that werent the right keys. So far no more problems and I havent did anything. Im sure the problem will happen again, so still replacing batteries and checking for a short.
TRANSFER
  • 1998 FORD MUSTANG
  • V8
  • FWD
  • 70,000 MILES
Electrical problem
1998 Ford Mustang V8 Front Wheel Drive Automatic 70,000 miles
EVERYTIME I LOCK MY CAR MY CAR THEFT ALARM GOES OFF.I CANT LOCK IT AT ALL.
HELP. WHAT CAN IT BE?
Thursday, March 9th, 2017 AT 2:05 PM (Merged)
RACEFAN966
  • 5,029 POSTS
Ok I need to know if your system is an active or passive system. To do this if you don't know you simply call the dealer with you vin number in hand and give them the vin and ask. Get back to me with what you have and I will get you the self diagnostic procedure to figure out what it going on. It may just a door jam switch who know's, but we can find out. Now use the pm button to get directly to me with a personal message and refresh me with what we are doing ok.
TRANSFER
I TRIED TO PM BACK TO RACEFAN 966 BUT YOUR SITE WOULDNT LET ME. SO HOPEFULLY HE SEES MY RESPONSE TO HIS QUESTION. FORD SAYS I HAVE A PASSIVE SYSTEM.
THANKS, DEBBIE
MUSTANGGUY1998
  • 1998 FORD MUSTANG
  • V8
  • 77,982 MILES
Electrical problem
1998 Ford Mustang V8 Two Wheel Drive Automatic 77982 miles
My 98 Mustang Car alarm has failed me I can set the alarm with the remote and in about 5 minutes or less the alarm goes off. I had a spare key made (one with out the chip) and I think someone used it to try to start the car to see if it would or not. Is there anyway to reset the car alarm? Please Help Thanks
MERLIN2021
  • 17,250 POSTS
Only way I know of is at Ford! One hour labor, and if you need a key get it there, they will program both.
AGAJESSICA
  • 1998 FORD MUSTANG
  • 138,000 MILES
My car alarm will go off when I'm sitting inside trying to get out. The car will be parked, and my boyfriend and I will go out to my car to smoke a cigarette. We will unlock the car by putting the key in the driver side door, I will then unlock his door from the inside. We get in and lock the doors. When we get out the alarm goes off often but not every time. I want to know what we are doing to trigger it sometimes? Does it have to do what order we open the doors, or is it because we unlock it from the inside to get out? I don't understand.
HMAC300
  • 48,601 POSTS
Try resetting security system if no manual look online. If it continues have a local pro scan for codes to see if anything is wrong with security system.
