2001 Mazda B2300 Jerks on Acceleration
RIVERRATBA
i have a 2001 B2300 pickup,4cyl,5 speed. it runs great but when you try to accelerate hard below 2500 rpms it jerks and acts like it's cutting out. you can accelerate slowly and it runs fine or anything above 2500 rpms it won't do it. it seems to be the worse around 2000 rpms. i've changed the fuel filter,spark plugs,plug wires and air filter.also cleaned the MAF sensor. 104000 miles on the truck
Jan 16, 2007 at 10:10 AM
  • 75,988 POSTS
Last Tune-up
Got OBD2 codes?
Try the TPS: Throttle Position Sensor
Jan 16, 2007 at 7:11 PM
RIVERRATBA
check eng. light is off,no trouble codes
Jan 17, 2007 at 1:35 AM
  • 75,988 POSTS
[quote:8f4445ee62="riverratba"]check eng. light is off,no trouble codes[/quote:8f4445ee62]
Might be the EGR opening too soon-creating a huge vacuum leak
Jan 17, 2007 at 7:32 AM
RIVERRATBA
thanks, i'll check it out
Jan 17, 2007 at 8:27 AM
Suggested Repair
Check the throttle position sensor and inspect the EGR valve for opening too soon, which can create a large vacuum leak and cause jerking under hard acceleration below 2500 rpm.
Conversation Summary
The owner of a 2001 B2300 4-cylinder manual pickup reported jerking and cutting out under hard acceleration below 2500 rpm, worst around 2000 rpm, while slow acceleration and higher rpm were fine. The fuel filter, spark plugs, plug wires, air filter, and MAF cleaning did not help, and there were no trouble codes. The expert suggested checking the throttle position sensor and an EGR valve opening too soon.
