1990 Ford F250 Fuel
22,000 MILES • V8 • 2WD • AUTOMATIC
TITANFENCE
If I hit the gas pedal to quickly there is a hesitation. sometimes the truck stops and I have to restart. Have changed to fuel filter no difference. It will happen either when I first start or leaving a signal? Has new air filter. Thought about new ignition wires and rotor. Just not sure. Thank you for any information.
joe
Sep 27, 2008 at 12:01 PM
  • 75,988 POSTS
Check the throttle position sensor/MAP sensor-might want to check the fuel pressure if its within specs. Won't hurt if you give it a minor tune-up
Sep 27, 2008 at 12:07 PM
TITANFENCE
That is really quick. Will do that........never hurts to have a tune up.
tnx's
joe
Sep 27, 2008 at 12:26 PM
