1997 Ford F-150 Window Stuck Up
HEAVNER
  • 6 POSTS
I have a 1997 V8 4.6L Ford F 150 supercab truck with power windows. The driver's side window is stuck in the up position. When you push the button to roll the window down, nothing happens. I took the window motor out and the motor works when it is not attached to the window gear. The window can be pushed down or pulled up manually but it is somewhat difficult. Is seems to me that if the motor will work without being attached to the window gear that something must be binding the window. Before the window stopped working, the window motor sounding like it was straining when pushing the window all the way closed. Could the motor be bad even though it works under no load or is something wrong with the window gear?
Thank you
Jan 6, 2007 at 9:37 AM
SERVICE WRITER
  • 9,123 POSTS
Without seeing it and your description, it sounds like the regulator is the problem.
Sure it is possible the window motor can move under no load, but too weak to move under load.
Jan 6, 2007 at 11:20 AM
Suggested Repair
Inspect the window regulator, which is the likely cause of binding. Also consider that the motor may be too weak under load even though it runs freely when disconnected.
Conversation Summary
The driver's power window on a 1997 Ford F-150 is stuck up. The motor runs when removed from the window gear, but the glass is hard to move by hand and the motor had been straining when closing. The expert says the regulator is likely the problem and notes the motor could still be too weak to move the window under load.
