2000 Ford F-150 Manual to Power Windows
MLANCECOLVIN
I have a 2000 Ford F150 with manual windows. Is the wiring in place in the truck so that I can replace the doors with the manual windows with doors with electric windows and just plug them into the wiring harness?
May 25, 2007 at 1:44 AM
FIXITMR
  • 9,989 POSTS
call the ford dealer and ask? i wouldn't think the wiring would be there. i dont believe it's any manufacturer's standard practice.not with the cost concerns.
Dec 15, 2010 at 6:44 PM
FIXITMR
  • 9,989 POSTS
actually, i misunderstood your question? i thought you were gonna replace the guts not the whole door. but i think when you replace door you pull out existing wiring. i dont think there is a plug that allows you to remove door with wiring intact. this is america, no 1 makes things that easy?
Dec 15, 2010 at 7:55 PM
  • 31,937 POSTS
Often all looms are intact but not used, just pull a trim and see if the harness is there, if not you will not easily be able to do a conversion.
mark (mhpautos)
Dec 15, 2010 at 11:00 PM
Suggested Repair
Pull the door trim and check for an unused power-window harness before swapping doors. Do not assume a plug-and-play connector is present. If the harness is missing, a conversion will not be straightforward and may require additional wiring.
Conversation Summary
The owner of a 2000 Ford F-150 with manual windows asked whether factory wiring is already present so power-window doors can be swapped in and plugged in. One expert doubted unused wiring would be there and said replacing a door generally means removing the existing wiring rather than using a ready plug. Another said unused looms are often present and recommended pulling the trim to check; if the harness is missing, conversion will not be easy.
