How do you remove a inner door panel from a 2002 Ford F-150?
Dec 9, 2006 at 4:39 AM
Remove all door-panel screws, pry the edges with a door-panel tool to release the clips, lift the panel upward, work it around the handles, and disconnect the electrical connectors. Consult the owner's manual so no fasteners or connections are missed.
The owner asked how to remove the inner door panel on a 2002 Ford F-150. An expert advised removing all screws, prying the clips loose, lifting the panel, working around the handles, and disconnecting electrical connectors. Another reply suggested following the owner's manual to avoid missing steps.
