2000 Ford F150 Removal of drivers door panel
31,500 MILES • 6 CYL • 2WD • MANUAL
MARCCARDS
I need to remove the drivers door panel to repair the rod for the door lock. It is currently dangling in a place that it is vibrating and making me nuts! Need to pull off the window crank and then the door panel. No power windows or locks.
Thank You,
Mark
Jun 22, 2008 at 12:41 PM
BLACKOP555
  • 10,386 POSTS
first try to remove the window cranks outter shell to see if there is a screw holding it in. if not grab a rag and rap it around the base of the window crank pretty tight and then give it a pull, should pop off!
Jun 22, 2008 at 2:16 PM
