2000 Ford F-150 Removing interior door panels
EDDIEDOVE
  • 2000 FORD F-150
  • 6 CYL
  • 126,000 MILES
I need to replace both side view mirrors. Is it true that I need to remove the interior door panels? How do I do this? Do I need special tools?
Tuesday, January 13th, 2009 AT 3:39 PM
PICKELFARMER
Yes you will need to remove the door panels. Pop off the arm rest cover, then the cover that the door handle runs through. There is one screw under this cover you will need to remove. Also you will need to pop off the molding that runs up the back side of the window. There is a screw under that piece of molding you will need to remove. Next lift the door panel and gelty pull panel away from door. You will need to disconect all the wireing that attaches to the door. Once you have removed the panel changeing the mirrors should be self explanitory. Good Luck
Sunday, January 25th, 2009 AT 6:06 PM
EDDIEDOVE
It worked exactly as you described it. I appreciate your help. Thanks a lot.
Monday, February 2nd, 2009 AT 11:26 PM
PICKELFARMER
No problem. Glad it worked for you.
Wednesday, February 4th, 2009 AT 8:05 PM
