2003 Ford F-150 Camper Light Power
BILL PEBLEY
I recently installed a new camper shell on my 2003 F-150 and I need to install lights inside it. Is there a always hot 12volt wire that I can connect to in the rear cab or under the truck in the bed area.
Im sure that Ford would have a factory installed wire just for this purpose but I don't know were to find it or what color wire to be looking for?
Thank you for your time as any answers will be greatly appreaciated.
Bill
2003 F-150 xtra cab short bed with V-6 engine, 72,000 miles
Jan 27, 2007 at 4:17 AM
JEFTFIELDS
  • 74 POSTS
if your truck has the tow package,it might have a hot wire in the trailer harness,for charging a battery,runninglights,ect,in trailers.and if so you will be able to tap into that wire.
Jan 27, 2007 at 7:11 AM
  • 75,988 POSTS
No factory hook-up, make your on from the battery with no.12 stranded wire thru a toogle switch and to the camper
It'll be perfect if your electrical system is a dual battery type.
Jan 27, 2007 at 7:20 AM
Suggested Repair
There is no factory always-hot hookup for camper-shell lights. Run No. 12 stranded wire from the battery through a toggle switch to the camper. A trailer-harness charge wire may be available only if the truck has a tow package; a dual-battery system is ideal.
Conversation Summary
The owner of a 2003 Ford F-150 wanted an always-hot 12-volt wire in the rear cab or bed for camper-shell lights. One reply said a tow-package trailer harness might include a hot charging wire that can be tapped. The expert said there is no factory hookup and recommended running No. 12 stranded wire from the battery through a toggle switch to the camper, noting a dual-battery system is ideal.
