2001 Ford F150 jerking at 45-55 speed
47,000 MILES • V8 • 2WD • AUTOMATIC
MCBRIDEM52
not sure what category took to repair shop said it maybe coil or spark plug or wiring he put it on his anaylsis it show nothing amiss in engine he said he fixed a wire but when we drove it still have the issue I thought it was the transmissiom but know one knows I get all different answers i purchased it last July and drove to I to Utah and back with truck bed filled with furniter and in Utah had to put sand baggs for snow 400lbs at 45-55 it starts to jerk alittle then i gas it to 60 it stops?
Apr 22, 2010 at 6:46 AM
JACKLE61
  • 7 POSTS
I had the exact same problem with my 2001 F-150. I scanned it and found no error codes so I started getting quotes for a transmission repair. I then hooked up my code reader and actually drove the truck for about 15min while making it do the jerking. Finally it showed a code that my #1 coil was bad. I think this is probably your problem. Now you just need to find someone to let you use their code reader while you drive it around for a bit. Hope this helps.
Apr 26, 2010 at 3:34 PM
