2000 Ford F-150 Power Locks Fail
you can either perform a continuity test or use a jumper wire to troubleshoot a single motor problem
Two other problems that can occur with a power door lock system are a failure of the ignition switch contact or failure of the main electronic control relay module
Suggested Repair
Check the gauge and power fuses first, then identify the failed component with a continuity test or jumper wire. Possible causes include a failed ignition-switch contact or the main electronic control relay module.
Conversation Summary
A 2000 F-150 owner reported that the power door locks would not work from either switch, although both locks moved slightly when a switch was operated, and asked whether the relay or both switches had failed. One reply suggested the relay, and another described using silicone grease on the actuators of a different vehicle. The expert recommended checking the gauge and power fuses, then using continuity or jumper testing to identify the failed component, noting possible failure of the ignition-switch contact or main electronic control relay module.
