1990 Ford F-150 Windows Won't Go Up
DARINGOINS
f150 lariat xlt,short bed,1990,158,000,v8, the window on the drivers side quit going up without help,the next day the passenger side did the same thing,the motors are both running and the windows go down but need help going up someone mentioned a relay switch in the dashboard? not sure hope you can help
Sep 26, 2007 at 10:09 AM
MERLIN2021
  • 17,250 POSTS
If it was a bad relay, you would not hear or get power to the motor! Changing the motor/regulator is most likely what you need!
Sep 26, 2007 at 10:54 AM
Suggested Repair
Replace the window motor and regulator. A bad relay is unlikely because the motors still run and receive power.
Conversation Summary
The owner of a 1990 Ford F-150 said both front power windows go down but need help going up, while the motors still run, and asked about a dashboard relay. The expert said a bad relay would not power the motors, so the motor and regulator most likely need replacement.
