1995 Ford F-150 Throwout Bearing
HOGCRACKER6969
I own a 1995 Ford F-150, 4.9 cyl, 160000 miles and a standard trans.,
My throw out bearing is going bad(or is bad), I want to know how much does something like this usaually cost, and would it be better to bring it to a local mechanic or a Tranmission Center? I really want to keep this truck for at least another 5 years or more, and while they are fixing the throw out bearing, should I have them do anything else while they have all this apart?
Aug 29, 2007 at 12:15 PM
BOOTDOG
  • 665 POSTS
is it a 4x4. if so it'll cost more. and if it's the bearing that's bad you might as well replace the clutch too. it's sold as an assembly.
Aug 31, 2007 at 1:15 AM
HOGCRACKER6969
it's not a 4x4, I just want a rough estimate so I won't get a heart attack when they hand me the estimate.
Aug 31, 2007 at 2:05 PM
Suggested Repair
Replace the throwout bearing and clutch together as an assembly while the transmission is removed. The truck is not a 4x4, which the expert said would otherwise raise the cost. No price or shop recommendation was given.
Conversation Summary
The owner of a 1995 Ford F-150 with a manual transmission asked about the cost of a failing throwout bearing, whether to use a local mechanic or a transmission shop, and what else to service while it is apart. The expert said a 4x4 costs more and recommended replacing the clutch with the bearing because they are sold as an assembly. The owner confirmed it is not a 4x4 and still wanted a rough estimate, which was not provided.
