1989 Ford F-150 Clutch Won't Bleed
J DUB
  • 5 POSTS
1989 ford f150 with 180 000 km. i bought the truck for 50 bucks with the original 5.0 l auto engine and tranny shot. I swapped the engine, tranny, wiring, fuel tank, driveshaft to make it a 4.9 l stick. everything is bolted up and it runs, but i can't get the clutch to bleed and the pedal is to the floor. I have a haynes manual on the truck, but their directions didn't work. believe me im not stupid i did what the book says, but i work in an underequipped home garage and can't really afford to take it to the shop. Any tips? :evil:
Apr 15, 2006 at 5:40 AM
LOSONE
  • 1,616 POSTS
Those set ups are usually self bleeding. I hope you replaced the slave cyl as it is inside the tranny housing. You can open a line from the master clutch cyl and see if you have fluid coimng out. If not it is the master cyl if you do than it is the one INSIDE the tranny housing. Good luck
Apr 15, 2006 at 5:44 AM
Suggested Repair
These hydraulic clutch setups are usually self-bleeding. Confirm the slave cylinder inside the transmission housing was replaced. Open a line from the clutch master cylinder and check for fluid: no fluid indicates a bad master cylinder; fluid present indicates the internal slave cylinder.
Conversation Summary
The owner of a 1989 Ford F-150 converted from an automatic to a 4.9L manual cannot bleed the clutch, and the pedal stays on the floor. Haynes manual steps did not work. The expert says these systems are usually self-bleeding, advises confirming the internal slave cylinder was replaced, and recommends checking fluid at a line from the master cylinder to tell whether the master or the internal slave is at fault.
