clutch adjustment
FORD F-150
MADMAN1956
1991 ford f150 2wd 4.9 5sp where is the clutch adjustment
Mar 19, 2007 at 2:01 PM
TAURUSWHEEL
  • 718 POSTS
I know on some of the cars with mechanical clutches, you have to hook your foot under the clutch pedal and lift it up, there was a type of ratchet system built into the pedal, not sure if yours is this way... if hydraulic not mechanical, isn't it a self-adjusting clutch???
Mar 24, 2021 at 12:21 PM
INDYUKE
  • 416 POSTS
The type of clutch you have is hydraulic and it is self-adjusting. If you have a suspicion that it isn't working to it's fullest, change the fluid and bleed the system.
