On my f-150 pickup she will rev. up to 2000 rpms when I push the clutch in ....why?
Mar 27, 2006 at 5:20 AM
Clean the throttle body, especially around the throttle plate, to remove carbon buildup that may be causing the high idle when the clutch is pressed, then recheck the idle.
The owner of a Ford F-150 reports that the engine revs up to about 2000 RPM when the clutch is pressed. A user suggested checking for an idle air control valve, and the owner confirmed the truck has one. The expert said the throttle body may be coked up and recommended cleaning it, especially around the throttle plate, then reporting back.
