1995 Ford F-150 High Idle
TY.PULL1963
hi, i own a 1995 ford 1-150 w/ a 5.8l engine w/ 53000 miles on it it runs like a gem but the problem is, that after i start it and let it get to normal operation temp, the idle will not come down can u help me with that?
Oct 13, 2007 at 3:17 AM
CHEVY22
  • 1,375 POSTS
hi
without knowing more , and if there are no codes i would suspect the idle air control motor on the throttle body , the get gummed up and stick , but im not saying thats it there could be a few other things , i would pull it off and check it and if it is clogged grab one from the store and replace it cleaning it will only work for a while and if there is an internal short cleaning will not help
jim
Oct 13, 2007 at 3:37 AM
INDYUKE
  • 416 POSTS
Check the coolant temp sensor as well. Sometimes it will go bad and see the engine as never warming up, causing the computer to keep the cold idle speed and mixture settings.
Oct 13, 2007 at 4:52 PM
Suggested Repair
Inspect the idle air control motor on the throttle body and replace it if gummed up, sticking, or internally faulty; cleaning is only temporary. Also test the coolant temperature sensor, which can keep cold-idle speed if it never reports a warm engine.
Conversation Summary
The owner of a 1995 Ford F-150 with a 5.8L engine says it runs well but the idle stays high after reaching normal operating temperature. Experts suggest checking the idle air control motor for sticking or clogging and replacing it if needed, and also testing the coolant temperature sensor in case the computer still thinks the engine is cold.
