1982 Ford F-150 Rough Idle When Warm
HONDA400
I just purchased a 1982 Ford f150 inline 6 (300), with AT. When the truck gets up to operating tempurature it starts to have a rough idle, and at times may stall out. Prior to reaching operating tempurature the truck idles great and never stalls.
Any ideas as to where I should start?
Thank you,
Eric
Mar 26, 2006 at 6:16 AM
PEPPERMRJ
  • 1,158 POSTS
Any maintenece history? Might just be in need of a tune up. Plgs, wires, cap, rotor, etc.
Fuel injection or carbeurated?
Good luck and :) post back.
Mar 26, 2006 at 8:01 AM
HONDA400
thank you for your reply...
It does have a carb, and I do not know the maint. history.
Thanks, Eric
Mar 26, 2006 at 8:39 AM
PEPPERMRJ
  • 1,158 POSTS
Six cylinders have a way of shaking the carb loose. Check it out. Do a tune up also. Plugs, wires, cap, rotor, PCV valve, fuel filter, and a tank of gas with intake/carb/injector cleaner. I like chevron with techron or seafoam.
Good luck and let us know. :)
Mar 26, 2006 at 10:31 AM
HONDA400
Thanks, I'll try that and let you know!
Eric
Mar 26, 2006 at 11:00 AM
PEPPERMRJ
  • 1,158 POSTS
Forgot to mention that the carb can come loose at the mounting bolts and the bolts/screws that actually hold the carb together. Check and tighten both as needed.
Mar 26, 2006 at 11:07 AM
LOVESCARS
  • 359 POSTS
Could be choke adjustment as well check adjustment after you done what peppermj has suggested above.
Mar 26, 2006 at 12:10 PM
Suggested Repair
Check and tighten the carburetor mounting bolts and the screws that hold the carburetor together, since inline-six vibration can loosen them. Perform a tune-up including plugs, wires, cap, rotor, PCV valve, and fuel filter, and run a tank of fuel with carburetor cleaner such as Chevron with Techron or Seafoam. After that, check and adjust the choke.
Conversation Summary
A 1982 Ford F-150 with a carbureted 300 inline-six and automatic transmission idles well when cold but runs rough and may stall once it reaches operating temperature. Maintenance history is unknown. Experts recommend checking for a carburetor loosened by engine vibration, completing a basic tune-up with plugs, wires, cap, rotor, PCV valve, fuel filter, and fuel-system cleaner, then checking choke adjustment.
