2002 Ford F-150 Ford F-150 Very Rough Idle
JASON F
  • 2002 FORD F-150
Engine Performance problem
2002 Ford F150 V8 Two Wheel Drive
I have a 2002 Ford F-150 with 106k miles that has a very rough idle. The check engine light came on about 2000 miles ago but the truck has been running perfectly so I didn't do anything about it. Now it has a very rough idle and makes a rattling sound when accelerating. The rough idle shakes the truck it is so bad. Then sometimes it will catch and the idle will rev high then go back down again. Is this an O2 Sensor issue or do I have bigger problems?
Tuesday, October 14th, 2008 AT 1:53 PM
JNOVACK
  • 723 POSTS
Go to autozone and have the code in computer read and let me know and I will help you through this thank you
Tuesday, October 14th, 2008 AT 6:30 PM
JASON F
Thanks! I was planning on doing that tomorrow. Will let you know as soon as I have it done.
Jason
Tuesday, October 14th, 2008 AT 6:47 PM
JASON F
I went and had the computer read and here are the codes that came up:
P0171
P0174
P0405
I went ahead and bought a MAF sensor because it looks like that is probably the problem but I haven't put it in yet. What do you think?
Thanks a lot,
Jason
Wednesday, October 15th, 2008 AT 6:48 PM
JNOVACK
  • 723 POSTS
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
with the codes it looks like o2 sensors on both sides and the egr valve
Wednesday, October 15th, 2008 AT 9:49 PM
JASON F
So should I scrap the Mass Air Flo sensor and just do the O2 sensors and EGR valve? Thanks a lot for your help.
Wednesday, October 15th, 2008 AT 10:02 PM
JNOVACK
  • 723 POSTS
The codes come up for the O2 sensors and egr I would go with them first
Wednesday, October 15th, 2008 AT 10:12 PM
