HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine Cooling
Cooling Fan
Clutch
SPONSORED LINKS
F-150 fan clutch
GORD5M
MEMBER
1915 FORD F-150
1988 300 cid 6 cyl, which direction does the nut unscrew
Saturday, November 24th, 2007 AT 12:59 PM
MERLIN2021
MECHANIC
This video will show you
https://youtu.be/N_-MLVlBHk8
SPONSORED LINKS
Saturday, November 24th, 2007 AT 4:35 PM
INDYUKE
MECHANIC
Except for the fan nut. Those are reverse threads.
Tuesday, November 27th, 2007 AT 9:16 PM
Please
login
or
register
to post a reply.
Related Cooling Fan Clutch Content
Leaksalot
Dear Bob And Ken My 1994 F150 5.0 302 2wd Truck With155000 Miles On It. Leaks From The Oil Pan On All Sides And A Little Off The Cranks...
Asked by
5.0 302
1 ANSWER
FORD F-150
VIDEO
How to Remove a Fan Clutch
Instructional repair video
GUIDE
Fan Clutch Symptoms
A fan clutch is designed to cool the engine when it becomes too hot and on the verge of overheating. These clutches are featured on forward facing engine's only and are used...
Coolant Flush Ford F150
I Have A 1997 4.6l V8 F150 Ford Supercab Truck With 74,000 Miles. I Plan To Change The Coolant And Flush Out The Radiator. My Plan Is To...
Asked by
theavner
1 ANSWER
1915
FORD F-150
Thermostat Replacement Instructions Please?
The Temperature Gauge Skyrockets Into The Red Only At High Speeds (65-70 Mph) And With The Heater On.
Asked by
bobcat9095
1 ANSWER
4 IMAGES
2004
FORD F-150
Do I Bleed Cooling System?
I Just Changed The Heater Core In My Truck And Heater Core Hoses Are Cold And Fluid Is Rising In The Overflow. I Am Trying To Bleed The Air...
Asked by
j.stieg
2 IMAGES
2005
FORD F-150
1976 Ford F150 Water Pump
My Truck Started Over Heating So I Put A New Thermostat In It About 30min. Ago. How Do I Now If The Water Pump Is Going Out. I Wigalled On...
Asked by
correy
1976
FORD F-150
VIEW MORE
SPONSORED LINKS
Fan Clutch Symptoms
Is Your Engine Cool Enough to Check?
Online car repair manuals
