1995 Ford E-150 Rough Idle
RRIG
My 1995 Ford E150 (approx 180,000 miles) idles rough and demonstrates a 'stutter' at highway speeds.
The rough idle only occurs when in drive (idles fine when in park) and when the engine is at normal operating temperature.
The check engine light is not on (no trouble codes have been produced).
Actions I have taken to date:
1. I have replaced the Exhaust Gas Recirculation (EGR) valve. (OEM Motorcraft part)
2. Verified the specified resistance (in Ohms) of the EGR position sensor
3. Verified the voltage at the EGR vacuum controller.
4. Checked for vacuumed leaks - found none.
I need advice on what else I can check.
Thanks
Jan 3, 2007 at 8:12 AM
2CARPRO JACK
  • 11,533 POSTS
Check fuel pressure, Mass Air Flow Meter.When was it tuned up last?. Any of those things can create a stutter or misfire.According to mileage you should be on your 2nd major tune up by now and I wouldnt be surprised to hear on your second fuel pump as well
Jan 3, 2007 at 8:53 AM
TAURUSWHEEL
  • 718 POSTS
Why did you replace the egr valve??? If your egr position sensor is bad, your pcm would pick it up and throw a code.. It's possible it's not really idling fine out of gear, just that being in gear amps it up to where you can feel an or hear it... as above poster said check those items, also possibly an o2 sensor could be crapping out, maybe switching slower then required... if your vehicle is obdI, a lot of issues won't necessarily set the check-engine light... have you had the computer scanned, both koeo and koer??? Sometimes things will show up in the latter test, but won't set the light as long as parameters are being met.. which may be at the edges. enough to cause issues that can be hard to track down.. don't replace things needlessly, it's a waste of $$$$...
Jan 3, 2007 at 9:07 AM
RRIG
Thanks for the prompt reply. I will check the Mass Air Flow Meter.
You are correct I have replaced the fuel pump twice, also recently replaced plugs, plug wires, distributor cap an rotor, fuel filter.
Thanks again
Ron
Jan 3, 2007 at 9:08 AM
TAURUSWHEEL
  • 718 POSTS
Another thing, it's possible your intake valves and or manifold may be crapped up, maybe a good cleaning may help...
Jan 3, 2007 at 9:11 AM
RRIG
What is the best way to clean the valves and intake?
Do I have to pull the heads? (I hope not, since it is a van, it is major pain to work on)
I'll probably have to break down and take it to a shop and have it computer scanned. I just hate to spend the cash on such an old vehicle.
Thanks for the reply
Ron
Jan 3, 2007 at 9:53 AM
SERVICE WRITER
  • 9,123 POSTS
There a couple ways. The easiest for you may be to use a couple castle products called hydroblast and cleansrite. GM top cleaner does the same pretty much as well. Hydro blast can be sprayed into a vacuum line while running such as the line off the vauccum booster. Spray at least 3 minutes and stall the engine. Let set for a few hours, the run the truck in a lower gear for a mile or so.
Cleanrite is sprayed through the thottle body-I like to scrub the plates while doing this with a brush.
Jan 3, 2007 at 10:05 AM
TAURUSWHEEL
  • 718 POSTS
What is it, obdI ??? Do you have a connector labeled EECIV, it's a black connector, usually in a holder on the firewall around the heater box... if you do, go buy yourself a code reader, probably around 30 bucks and learn to use it, relatively simple.. not only that. even though it doesn't say so, it can also be used to pull abs codes from so-equipped vehicles, it uses the same type of connector,they're located in tandem on the firewall... I recommend everyone who plans on keeping their car for any length of time get a reader for their vehicle, you don't need to get fancy with it.. one trip to the dealer costs more then the reader.. even if you need obdII, I think some 95's may have been, you can pick up a scanner for less then a 100 bucks.. ServiceWriter has it right with the cleaners, there are several, follow the directions, may take a couple of times to get it cleaned up..
Jan 3, 2007 at 12:49 PM
Suggested Repair
Check fuel pressure and the mass airflow sensor, and scan the computer in KOEO and KOER modes, including a possible slow oxygen sensor. Clean the intake valves, manifold, and throttle body with an approved intake cleaner; pulling the heads is not required.
Conversation Summary
A 1995 Ford E-150 with about 180,000 miles idles roughly only in Drive at normal temperature and stutters at highway speed, with no check-engine light. The owner replaced the EGR valve, verified the EGR sensor and vacuum controller, found no vacuum leaks, and later reported two fuel pumps plus plugs, wires, cap, rotor, and fuel filter. Experts advised checking fuel pressure and the mass airflow sensor, scanning KOEO and KOER, considering a slow oxygen sensor, and cleaning the intake and throttle body rather than replacing parts unnecessarily.
