1994 Ford Crown Victoria Rough Idle
MILTONPUCKETT
1994 ford crown victoria 4.6 v8 52,000mi
starts fine and runs great but it idles rough, and today it stalled on me. my check engine lite comes on and off while driving. I was told that it might be the o2 censor, but wanted to get your opinion.
Mar 5, 2007 at 1:54 PM
TAURUSWHEEL
  • 718 POSTS
You need to get it scanned for whatever is setting the light to come on and off,,, your car is obdI, I'm not sure if parts stores scan obdI, I know most do obdII.. you can buy a scan tool for your car for like 30 or so bucks, it's easy to use, comes with good instructions...
Mar 5, 2007 at 3:07 PM
Suggested Repair
Scan the OBD-I system for the codes that turn the check engine light on before replacing parts. Use an OBD-I scan tool if a parts store cannot read OBD-I codes.
Conversation Summary
The owner of a 1994 Ford Crown Victoria reports a rough idle, a stall, and an intermittent check engine light, and was told the oxygen sensor might be the cause. The expert advised scanning for diagnostic codes first, noting that the vehicle uses OBD-I and that an inexpensive scan tool may be needed if a parts store cannot scan it.
