Car is hard to start in cold or wet weather, it needs around 5 minutes of warm up time before operating normally. If you try to drive off before the engine is warm the car sputters, small backfire in the intake, and will not reach speed above 15mph until engine is warm. So far I repalced the coils, testing proved resistance accross the terminal was around 14.5 ohms, according to the manual the max is 13 ohms. Since I was under the hood I also replaced the plugs, wires, air filter, and fuel filter. Someone suggested I repalce the ICM, if the problem still existed disconnect the ERG system and close off the vacume lines, still no solution. Any Ideas as to what could be causing this?
1994 Ford Crown Victoria Cold Start Rough
Look for vacuum leaks when cold. Test the PCV and EGR-Open the EGR and check thoroughly for blockage/check the operation of the throttle position and MAP/BARO sensor.
Suggested Repair
With the IAC and coolant temperature switch already replaced, check for vacuum leaks when the engine is cold. Test the PCV valve and EGR valve, opening the EGR to inspect for blockage and proper operation, and verify the throttle position sensor and MAP/BARO sensor.
Conversation Summary
A 1994 Ford Crown Victoria 4.6L is hard to start in cold or wet weather and sputters, backfires lightly through the intake, and will not exceed about 15 mph until it warms up. Coils, plugs, wires, air filter, and fuel filter were replaced, and disconnecting the EGR and closing vacuum lines did not help. After the IAC and temperature switch were also replaced without improvement, the expert advised checking cold vacuum leaks, the PCV and EGR, and the throttle position and MAP/BARO sensors.
