2000 Ford Explorer Rough Idle
BSWINTON
For about a year now my 2000 Ford Explorer with a 4.0 V-6, 112000 miles has had rough idling and very rough starting (at times will not start). The check engine light has come on numerous times. The first time I brought it in to the shop and they cleaned the fuel system out with the checmical solution stuff. That adventually led to a jammed plunger in a fuel injector on cylinder 3. So, in turn I got all 6 fuel injectors replaced. For awhile it ran fine and then the check engine light went on again and rough idling/staring persisted. This time i brought it in and they replaced the spark plugs and spark plug wires. It ran good for awhile again, but now it is back to rough idling and starting yet once again. Help... (FYI I have also noticed that when i add fuel system cleaning products the engine begins to run worse).
Feb 20, 2007 at 12:36 PM
NOS
  • 320 POSTS
first things first injector cleaners a lot of times do more harm that good. has anyone checked your fuel pressure or changed the fuel filter ? carbon under an EGR valve can cause hard starting and rough idleing has anyone checked this out for ya ? the only thing you should use in your tank should be (Heet) it comes in a yellow or red bottle and it helps to burn moisture that gets in in the gas.NOS 8)
Feb 20, 2007 at 1:40 PM
Suggested Repair
Check fuel pressure and replace the fuel filter if needed. Inspect the EGR valve for carbon buildup that can cause hard starting and rough idle. Avoid fuel-system cleaners; if moisture in the fuel is suspected, use only a moisture-removing additive such as Heet.
Conversation Summary
The owner of a 2000 Ford Explorer 4.0 V6 reports ongoing rough idle and hard starting after fuel-injector replacement and new spark plugs and wires. Fuel-system cleaners made the problem worse. The expert advises checking fuel pressure and the fuel filter, inspecting the EGR valve for carbon, and avoiding injector cleaners.
