1970 Ford Mustang Rough Idle
ALLISONEALE
I have a 1970 Ford Mustang w/302 engine. Car has low miles and the engine is strong.
Car has had some minor overheating issues, but will only want to overheat when driving at high speeds or climbing hills. I can cruise all day long driving between 10-50 miles an hour.
Coming home the other night from a 30 min cruise I got the car going a little faster than 50 miles an hour and could see a very small amount of smoke or steam coming from the engine. I immediately slowed down and coasted the car for a bit to cool it down and then parked it. Popped the hood...no burning smell or no leaks...everything seemed fine. Then when i put it in gear to put in the garage, the car started to idle rough. I just parked it and turned it off. 4 days later I started the car up to see what gives and she started up perfectly, but is idling rough in park and in reverse or drive.
Also, when I pulled the car out of storage 1 month ago and was putting the spark plugs in one of them made a slight crack noise when screwing it in...I pulled it back out easily and there was just a small crack on the ceramic so I reinstalled it and have been driving the car fine until now.
I'm wondering if my rough idle problem is because of the spark plug or something else related to the engine or cooling system?????
May 25, 2007 at 1:57 AM
RUDPRO
  • 224 POSTS
The cracked spark plug would definately cause problems. Replace it. I would also service the cooling system, flush it change the thermostat and see if that helps. You my have a thermostat not opening when it should.
May 25, 2007 at 5:57 AM
Suggested Repair
Replace the cracked spark plug. Flush and service the cooling system and replace the thermostat, which may not be opening when it should.
Conversation Summary
The owner of a 1970 Ford Mustang with a 302 reports a rough idle after a higher-speed or hill drive that produced slight steam or smoke and minor overheating. A spark plug ceramic cracked during installation and was reinstalled. The expert says the cracked plug can cause the idle problem and recommends replacing it, flushing the cooling system, and changing the thermostat.
