I changed the plugs and the boots in my 5.4lt and I had 1 coil pack retainer bolt that will not come out, the nut sert is spinning I tried to clamp vise grips on the plastic surrounding the nutsert which is part of the intake but I cannot hold it I guess the bolt has seized up in the nutsert. I thought about cutting the head off then try to remove the bolt and nutsert from it's plastic then install a nut and new bolt but I dont want to break the intake manifold, the coil pack has to have downward pressure just to hold it in place have you any advice it will be greatly appreciated
SPONSORED LINKS
Saturday, July 11th, 2009 AT 12:14 AM
