My Uncle gave me his truck to fix. The truck idles rough. But smothes out on excelleration. He replaced the cats for they where glowing. All the cylinders have almost 170psi I have replaced fuel injectors. Still the problem exist is there a way to check timing on a truck with a coil pack if so how?
SPONSORED LINKS
Tuesday, March 9th, 2010 AT 11:12 PM
BLACKOP555
MECHANIC
What is the fuel pressure in the system.
If the cats are glowing they are gettign too much fuel
Wednesday, March 10th, 2010 AT 9:58 AM
ALLEN21
MEMBER
The fuel pressure is at 40psi I got the right timming from the dealership but the problem still exists. Do you think the injectors are running wide open?
SPONSORED LINKS
Thursday, March 11th, 2010 AT 3:48 PM
BLACKOP555
MECHANIC
They can infact be hanging up and not shutting off or just being told to be on tooo long.
