HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Trouble Codes
P Codes (Powertrain)
P0400 - P0499
P0401
Code P0401?
PREV
1
2
3
4
NEXT
MECHANIC
No, there is not.
You need a scan tool as I stated to monitor the voltages. It varies on catalytic converter activity as well as load factors.
Monday, January 11th, 2021 AT 10:14 AM (Merged)
WHITESHIRTSAMMY
MEMBER
Okay, let me work on it.
MECHANIC
Sounds like a plan.
WHITESHIRTSAMMY
MEMBER
I do not have vacuum at the EGR solenoid.
MECHANIC
You should have manifold vacuum at the solenoid. When the solenoid opens, it will send vacuum to the EGR. That is not the issue for the 401.
Check all your vacuum lines for cracks or breaks.
WHITESHIRTSAMMY
MEMBER
I am still working on this.
MECHANIC
Okay, I am here.
Monday, January 11th, 2021 AT 10:15 AM (Merged)
WHITESHIRTSAMMY
MEMBER
Okay, all new vacuum tubing in the truck. I cleared the code, drove the vehicle and now the code is P0402.
MECHANIC
Did you replace the sensor?
WHITESHIRTSAMMY
MEMBER
No, same delta feedback pressure sensor as when I was getting P0401.
MECHANIC
Replace the sensor. That was a very common failure for the 401 code.
WHITESHIRTSAMMY
MEMBER
Is there a brand I should stay away from?
MECHANIC
I would get an OEM from Ford. I have had trouble with aftermarket sensors.
WHITESHIRTSAMMY
MEMBER
Okay, that fixed it.
MECHANIC
Good job.
PREV
1
2
3
4
NEXT
Please
login
or
register
to post a reply.
Related P0401 Content
P0401 Code Egr
Have P0401 Code Egr. I Have Changed The Egr Valve, Egr Solenoid And Sensor. Still Have The Code.
Asked by
jimtam
1 ANSWER
1 IMAGE
1997
FORD F-150
1996 Ford F-150 Code P0443
This Code Appeared Obdii System. I Know This Involves A Malfunctioning Canister Purge Solenoid. However, I Cannot Find It On This Truck. I...
Asked by
robertmoore934
3 IMAGES
1996
FORD F-150
1996 Ford F150 Dtc P0443
Evap Emissions Dtc P0443 Is Present. How Do I Fix It? Thanks Rod
Asked by
falconcar
1996
FORD F-150
Sensor Circuit B That Code P0407
What Is The Sensor Circuit B That Code P0407 Is Talking About? I Also Have A Random Hesitation On Acceleration And Innermitant Pop In Th...
Asked by
Troy Clapp
1 IMAGE
2002
FORD F-150
2001 Ford F150 Code Po460
How Would I Fix Fuel Level Sensor. I Connected The Code Reader And This Is The Code It Came Up With Po460
Asked by
caligal64
2001
FORD F-150
VIEW MORE
Topdon OBD2 Scanner Review - This thing rocks
Code Read Retrieval/Clear Chevrolet
Code Read Retrieval/Clear Mercedes-Benz C230
