1999 Ford E-150 Power Door Locks
JOHNEBULLOCK
The power door locks in my 99 Ford E-150 with 65,000 miles quit working yesterday, either from the remote keyless entry fob or the inside switches. All locks are affected.
I checked the user manual fuse chart and found what I think is the correct fuse, and it was not blown. I replaced it anyways with a new one, and it made no difference.
Whar is the next thing I should check?
Jul 5, 2006 at 5:25 AM
MIKEYBDMAN
  • 623 POSTS
well, unless u have a memory lock module, I would say the master window/door lock control switch is probably the problem. All of the other door locks go thru this switch to lock the doors. It looks like the fuse should be a 20a fuse on the central junction box
Jul 8, 2006 at 1:00 PM
Suggested Repair
Confirm the 20A fuse in the central junction box, then inspect or replace the master window/door lock control switch, since the other locks route through it. If the van has a memory lock module, check that as well.
Conversation Summary
A 1999 Ford E-150 owner reported that all power door locks stopped working from both the keyless-entry fob and the interior switches. The fuse listed in the manual was not blown and replacing it did not help. The expert said the fuse should be a 20A fuse in the central junction box and that, unless a memory lock module is present, the master window/door lock control switch is the likely cause because the other locks operate through it.
