I have a 2001 Ford F-250 Super Duty crew cab (4 door), 64,000 miles, auto with 7.3 lt Diesel. The driver's door became hard to unlock with button on door and key fob. I sometimes will not open with key in door lock. I took door apart, checked linkage, lubed and reassembled. It still is dificult most times. Now the other 3 doors are behaving the same. Most times, I'm unable to get them to unlock with key fob or door switch. They will work manually. All attempt to work with switch and keyfob, just not enough. Is this a problem with all of the doors or an electrical/ground problem with the control?
Oct 13, 2007 at 11:52 AM
