1999 Ford Contour Power Door Locks
0LD$MOBILE
I have a 1999 Ford Contour with 77,000iles. The power door locks are not working, the fuse is good but neither of the front door lock switches work. Any idea's? What do I do to diagnose the problem? Thanks!
Dec 15, 2006 at 10:09 AM
CARUNDELL
  • 602 POSTS
[quote:926f108cc1="0Ld$mobile"]I have a 1999 Ford Contour with 77,000iles. The power door locks are not working, the fuse is good but neither of the front door lock switches work. Any idea's? What do I do to diagnose the problem? Thanks![/quote:926f108cc1]
Hey Old$,
Some things to check, power door lock switch and the wiring between the door and door post, the harness passes thru a large rubber boot and over time the wires sometimes break due to opening and closing the door. The door lock actuators are a possibility, but it sounds more like a switch/wiring issue
Chris
Dec 15, 2006 at 8:25 PM
2CARPRO JACK
  • 11,533 POSTS
I would definitly start with the drivers side when looking for the problem. The grounds and powers are routed through the D/S switch first.Definitly could be a bad wire in the doo rjamb, or just the switch
Dec 16, 2006 at 12:35 AM
Suggested Repair
Start at the driver-side door lock switch, since power and ground are routed through it first. Also inspect the wiring in the door-to-body harness where it passes through the rubber boot in the door jamb for broken wires. Door lock actuators are less likely if both front switches fail.
Conversation Summary
The owner of a 1999 Ford Contour reports that the power door locks do not work, the fuse is good, and neither front door lock switch operates. Experts recommend checking the driver-side switch first and inspecting the door-jamb wiring in the rubber boot for breaks from repeated door movement, noting actuators are a lesser possibility.
