• HOME
  • ASK A QUESTION
  • REPAIR GUIDES
  • BECOME A MEMBER
  • LOG IN
    Login with Facebook
    OR
    NOT A MEMBER?FORGOT PASSWORD?
  • CONTACT US
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
  • Home
  • Ford
  • F-150
  • Interior
  • Cruise Control
  • Not Working
Cruise control stopped working
  • PREV
  • 1
  • 2
  • NEXT
WRENCHTECH
  • 20,761 POSTS
Being that it's a tilt wheel, that makes it much more difficult and requires a few special tools. I wouldn't recommend trying this yourself. It has some real high power springs in there also.
Tuesday, June 9th, 2020 AT 12:30 PM (Merged)
  • PREV
  • 1
  • 2
  • NEXT
Related Cruise Control Not Working Content
Cruise Control
The Cruise Control On My 2004 F-150 Quit Working. What Could Be The Problem?
Asked by KORNBEAN ·
6 IMAGES
2004
FORD F-150
2001 Ford F150 Cruise Control Stopped Working
Ever Since I Had The Recall Work Done On My F150, The Cruise Control Will Not Function. I Am Not Sure Which Fuse Or Fuses To Check To...
Asked by brriner ·
1 ANSWER
2001
FORD F-150
1997 Ford F150 97 F-150 Cruise Doesn`t Work
Have A 97 4.6 F-150 Excab 4x4 The Cruise Don`t Work. Looked In The Manual.I Check All The Fuses, Also Change The Bulb In The Upper Brake...
Asked by MAGIC2756 ·
1997
FORD F-150
2004 Ford F150 Cruise Control Switch
I Would Like To Know The Procedure To Replace The Cruise Control Switch. I Have A Replacement Switch, The Oem Switch Was Damaged By My Dog...
Asked by MAXIMUX ·
1 ANSWER
2004
FORD F-150
2006 Ford F-150 Adding Cruise Control
Hello. I Added Cruise Control To The Vehicle That Did Not Come From The Factory. This Include Steering Wheel Switches And Flashing The...
Asked by miec ·
3 IMAGES
2006
FORD F-150
VIEW MORE
How to Use a Test Light
Blend Door Actuator Replacement
Door Panel Removal
Door Panel Removal
  • Contact
  • Help
  • About
  • Privacy Policy
  • Terms & Conditions
© 1999 - 2025 2CarPros, Inc.
