1997 Ford F-150 97 F-150 Cruise doesn`t work
MAGIC2756
  • 1997 FORD F-150
  • V8
  • 4WD
  • 276,216 MILES
Have a 97 4.6 F-150 Excab 4X4 the cruise don`t work. Looked in the manual.I check all the fuses, also change the bulb in the upper brake light on the back of the cab because it was out. Cruise still did n`t work. Had a friend tell me to unplug the brake switch on the master cylinder and cruise still did n`t work. For got to check the horn.
Tuesday, May 18th, 2010 AT 10:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Does cruise indicator light come on when trying to set cruise or does it not light at all?
Tuesday, May 18th, 2010 AT 10:20 PM
MAGIC2756
  • 12 POSTS
Hello Thanks for all your help found a wire in the left front fender well broken cruise work now thanks again for everything
Tuesday, May 18th, 2010 AT 10:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Will need to follow diagnostic steps below to find the culprit .
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2188.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_709.jpg
Tuesday, May 18th, 2010 AT 10:52 PM
