1991 Ford F150 Truck Failed Emissions
490,000 MILES • V8 • 2WD • AUTOMATIC
BUDATATTOO
  • 12 POSTS
I recently bought an old F150 with the 4.8L motor. I took the truck to emissions and it passed everything except hydrocarbons in idle. The truck is running real rich because there is a strong gas odor. The limit is 220 and mine is 1235. Is it a faulty oxygen sensor? I just replaced the water pump, plugs and wires, and cap and rotor. The truck runs solid but rough. I am a single mom and have no clue where to start. I took it to Meineke and they said it was the EGR but they also charged me for work they never performed. Rip offs! Could it be the EGR? Any help would really be appreciated. Thanks!
Mar 13, 2010 at 5:02 AM
  • 110,246 POSTS
Does it actually have that many miles?
Mar 13, 2010 at 8:54 AM
BUDATATTOO
  • 12 POSTS
It has a little over 482,000 according to my odometer! But do you know anything about why the hydrocarbons are so high in idle so I can get it to pass????
Mar 13, 2010 at 12:25 PM
  • 110,246 POSTS
I needed to know if the mileage was correct. Chances are (with that many miles) the compression in the engine is getting weak and all of the fuel isn't getting burned. I would start with checking compression to make sure it is within spec. If it is, then we need to check O2 sensors...
Let me know if you need directions for checking compression.
Mar 13, 2010 at 2:06 PM
BUDATATTOO
  • 12 POSTS
I didn't until I busted out my haynes manual for my broke down car. That is another story. I don't have a compression gauge and that's a problem if they are expensive. I know I have a valve cover leak on the drivers side that's pretty bad and I'm going to try to tighten it down in the morning. I actually bought new valve cover gaskets but now that I have to drive the truck everyday I don't have enough time to take all that intake apart. Am I correct that there are three oxygen sensors on the truck and they all are the same? I was thinking I could get a sensor and try it in each one to see if it works? Then hopefully return it if it's not my problem.
Mar 13, 2010 at 3:17 PM
  • 110,246 POSTS
As far as the compression gauge, most nationally recognized parts stores will lend them to you for free. Basically, when you get it, you pay them for the tool. WHen you return it, they give the money back. As far as the O2 sensors, you could give it a try to see if it helps.
Mar 14, 2010 at 9:40 AM
BUDATATTOO
  • 12 POSTS
Hi Joe,
I called autozone this morning and it's 38 bucks to rent a gauge so I am going to go get it and a sensor this weekend. Hopefully the sensor works:) I'm thinking if the compression is bad it's probably the valves because of the oil leak. Wish me luck and thanks!
Joyce
Mar 15, 2010 at 12:26 PM
  • 110,246 POSTS
Joyce:
THey should refund the money when you return it. If they don't, you can buy one for that amount.
I will be checking my email all weekend, so if you have questions or concerns, let me know and I'll do my best to help.
Mar 15, 2010 at 2:03 PM
BUDATATTOO
  • 12 POSTS
Hi Joe,
I tightened up the valve cover, replaced the O2 sensor and dropped sum lucas in the tank. I did not do a compression test for the shear fact that even if the compression has gotten weak there is nothing I am able to do about it at this time. Valve jobs are not within my capabilities when I have to drive it every day. I am going to attempt one final thing and that is the EGR because it was another code that showed up. Wish me luck and thanks for everything.
Joyce
Mar 20, 2010 at 2:47 PM
  • 110,246 POSTS
Joyce:
WHen you remove it, chances are there will be carbon built up in both the egr and the intake. Make sure to clean it. After cleaning, check to make sure the valve is opening and closing properly.
Let me know what you find or if you have other questions, and GOOD LUCK.
Mar 20, 2010 at 4:33 PM
BUDATATTOO
  • 12 POSTS
Joe,
Is there anything in particular I should use to clean them out? Someone told me rubbing alcohol. Is that correct? My engine has some surging, so I'm hoping cleaning/replacing the egr is what is needed. I also have two skinny little intake lines (one red, one black) that have been cut off but are supposed to go to a "can" on the passenger side. Could this be a possibility for the truck failing emissions? I'm racking my brain trying to find a solution. As always any help is appreciated.
Thanks,
Joyce
Mar 20, 2010 at 5:12 PM
  • 110,246 POSTS
I think you are refering to the charcoal canister. THere should be lines going to them. It collects fumes from the fuel tank and they get burnt through the intake. So to answer your question, yes it could cause an emission problem.
As far as the carbon, it is usually really hard. You will most likely end up chipping it away. However, I use brake cleaner once I get the majority out. It cleans good and evaporates really fast too. Just make sure you are in a well ventilated area. It stinks!
Mar 20, 2010 at 5:38 PM
BUDATATTOO
  • 12 POSTS
Hi Joe,
It's the damndest thing but I passed emissions today! Don't get me wrong I'm grateful but if I knew how I did it then I could correct what is still wrong. So let me start from the beginning and maybe you can help me! I took the truck to emissions the first time and my loaded hydrocarbons were 115/220 and my hydrocarbons in idle were 1235/220. My CO in idle was .44/1.20 and loaded was .03/1.20. I replaced the water pump, plugs and wires, o2 sensor, cap and rotor. I also ran a 3-step fuel/intake system cleaner threw it yesterday foregoing the egr until I had it put on a diagnostic, and sprayed a little intake cleaner in the egr. By the way, when they ran it on the obd 1 diagnostic the only code they pulled was 67 and not an emisssions related code. Today I replaced to skinny vacumn lines going to the charcoal filter and had ran good gas in it for a couple of days.
Anyhow, this is what I would like to know. Today when they tested it my hydrocarbons in idle were 166/220 but my hydrocarbons loaded were 219/220. What is going on? I'm thinking the hoses were cut to pass hydrocarbons in idle once upon a time but why are they barely passing loaded now? I am going to do my homework to the best of my ability but any foresight would be helpful. Emissions will happen again!
Thanks,
Joyce
Anyhow, this is my
Mar 29, 2010 at 1:14 PM
  • 110,246 POSTS
Chances are the hoses and all the other things you did caused it to pass. A good tune up can do wonders.
Mar 29, 2010 at 4:26 PM
BUDATATTOO
  • 12 POSTS
Joe,
I'm glad all my hard work was not in vain but I am concerned about the HC's still being so high under load because I barely made it. I did some checking and came up with this list of possible causes:
Elevated HC readings during acceleration indicate ignition misfire under load. The causes could be:
Defective knock sensor;
Weak ignition coil(s);
Excessive resistance in spark plug wires;
Arcing inside the distributor cap;
Worn, fouled or incorrectly gapped spark plugs;
Over-advanced ignition timing; or
Lean air/fuel mixture.
If you have anything to add please let me know.
Joyce
Mar 30, 2010 at 12:58 PM
  • 110,246 POSTS
Joyce:
Any of them could cause it. Some are tied together. For example, a bad knock sensor will affect the timing. Is the engine missing?
Apr 1, 2010 at 12:24 AM
BUDATATTOO
  • 12 POSTS
Joe,
I haven't noticed any misfire but what I have noticed is the timing does seem really high. I also noticed that I need a fan clutch because the fan is moving real slow. I need a new drive belt because it's got a bunch of little cracks and it bogs down when I get on the gas. I'm thinking fuel filters because I've run a ton of injector cleaner threw it and hoping it's not the pump. The motor seems to jump around a lot too, so I am going to check the mounts. I'm going to try to work on the fan and serpentine this weekend but I have a lot to do before Easter.
Happy Easter,
Joyce
Apr 1, 2010 at 1:52 PM
  • 110,246 POSTS
Joyce,
Let me know when you get started. We're the same here with Easter. The fan clutch can be a pain so let me know when you replace it. I have a little trick to get it off. The special tools they make for them are junk.
Let me know when you're ready.
Apr 1, 2010 at 4:08 PM
BUDATATTOO
  • 12 POSTS
Hi Joe,
Hope your Easter was good. I went today and bought the fan clutch for the truck but I'm not going to mess with it until I'm off on Saturday. I bought a truck for parts this past weekend but the motor was different and so was the clutch. I got lots of other great parts I need to put on though! Anyhow, I've been reading up on the fan clutch and a lot of people have said that the rental crap to get it off at Autozone is junk. So if you have any great ideas to make my life easier I would be happy. Also, if you have a recommendation on a reasonable sized compressor to run air tools that would be great because my elbows get to killing me:)
Thanks,
Joyce
Apr 6, 2010 at 3:19 PM
  • 110,246 POSTS
You will laugh at me if I tell you how I remove them. I take a large cresent wrench, wedge something behind the waterpump pulley, and smack the wrench a few times with a dead blow hammar. It usually takes a few hits, but the nut will come loose. Also, don't remove the belt. It will help prevent the waterpump from turning.
As far as a compressor, at my house I have a small one. If I recall, it has a 20 gallon tank and is 5hp (electric). It keeps up with my tools really well.
Let me know how it goes and no laughing at my method. I can't believe I posted it on the internet. Now everyone will think I'm a hack at my job. (LOL).
Apr 6, 2010 at 3:58 PM
BUDATATTOO
  • 12 POSTS
You know what they say about he who laughs last! Necessity is the mother of invention and I'm not laughing if it works! I'm going to look into a small compressor like what you have because it will definitely make my life easier. I will let you know how it goes Saturday and thanks!
Joyce
Apr 7, 2010 at 1:06 PM
  • 110,246 POSTS
Good luck and I look forward to hearing from you.
Apr 7, 2010 at 1:43 PM
BUDATATTOO
  • 12 POSTS
Hi Joe,
Well the fan clutch was a heck of a lot easier than I thought it would be and definitely easier than the bumper! I followed your advice and left the belt on, I only unscrewed the top of the shroud. unscrewed the four bolts to the water pump and it came right off:) It was a bit of a pain getting it back in the shroud since I took the lazy way but it works great. The new drive belt was a snap too and now I don't think my idle is high at all. I also replaced the bumper, the efi piece above it and the headlight/turn signal assembly. The previous owner had wrecked it and that is why I stripped that other truck last weekend. Looks a hundred percent better. I have noticed that I am losing coolant though and I fear it is my head gasket. It's not at a rapid pace and I always fill it when it gets low but still not good. It has a new water pump, haven't seen any radiator leaks but I did buy some radiator sealant that is supposed to help the heads. I'm hoping since it is not a gapping hole that it will bandaid it until I get some real money. If I had my way I'd have the engine rebuilt! I know you're thinking why the heck do I keep sinking money into such an old truck but still to this day I calculated it and I have only spent 2100 including the truck. Besides, I love the truck.
Joyce
Apr 11, 2010 at 2:46 PM
