2002 Ford Explorer Cranks But Won't Start
ROBYNLB
Hello.
I have a 2002 Ford Explorer XLT, with 36,000 miles.
Once in a while I go to start the vehicle, and it will turn over, but won't start - I tried giving it some gas while trying to start it, that seems to work.
It does not stall, or idle low - It just occasional will not start without giving it gas.
Everything else is fine with the vehicle.
Can you help me please?
Mar 27, 2006 at 2:39 AM
RAYHUT
  • 134 POSTS
check your gas pump sometimes they seem to work alright but don't.then you might need to replace your coil.
Mar 27, 2006 at 3:11 AM
Suggested Repair
Check the fuel pump, which can seem to work but fail intermittently. If that is not the cause, the ignition coil may need to be replaced.
Conversation Summary
The owner of a 2002 Ford Explorer XLT with 36,000 miles reports that it occasionally cranks but will not start unless the accelerator is pressed. It does not stall or idle poorly otherwise. The expert advised checking the fuel pump and possibly replacing the ignition coil.
