1995 Ford Explorer Knock at Stop
BONDSPY
1995 Ford Explorer, 4.0L, Milelage - 225,022 and still going! My question is: when coming to a complete stop, my transmission seems to let out a single knock, then I immediately feel a shaking under my brake peddle. I had a rebuilt tranny installed just last february, might it have to be replaced again, or could it possibly just need a fluid change?
Aug 28, 2007 at 11:19 AM
MERLIN2021
  • 17,250 POSTS
Have your mount checked.
Aug 30, 2007 at 8:34 AM
ZUCKTUCKER
  • 5 POSTS
95 4WD w/ 217K miles. Has had intermittent thumping noise from dirver front side area when going from 1st-2nd gear--ever since the car was new. Ford could never find the problem. Engaging the 4WD stops the noise. Had the r front 4WD shaft replaced--now noise occurs more frequently and when coming to a stop or starting out, then goes away. Have replaced front and read diffy gear oil with posi-additive. My local shop suspects the xmission but I don't agree. Noise remains even if xmission is put in nuetral. Could the front Diffy gears be malfunctioning? Any help would be appreicated.
Nov 16, 2007 at 1:53 PM
Suggested Repair
Have the transmission or engine mount checked before considering another transmission replacement or a fluid change.
Conversation Summary
A 1995 Ford Explorer with a recently rebuilt transmission knocks once when coming to a complete stop, followed by shaking under the brake pedal. The owner asked whether the transmission needs replacement or only a fluid change. The expert advised having the mount checked. A later comment described a separate front-end thumping concern but received no expert reply.
