2000 Ford Explorer High Speed Rattle
ABIEZER73
  • 6 POSTS
My ford explorer sport 2000 (manual transmission) with 60000 miles has had a noise for about 4 months. It is like a rattle but not to loud. It happens in different situations. When I am the highway and accelerate very hard with one pedal-push (at high speed only), it makes this noise while accelerating for a few seconds until I reach the desired speed. When the car reaches 65-70 mph or more and I keep it on 70 mph or higher, it maintains this noise solid until I reduce to less than 70 mph. I had another truck long time ago with the same problem. Someone told me it was the oil I was using (too heavy). I never had the chance to check if that was the problem ‘cause I lost it in a crash. Now, I use Castrol full synthetic 10-30 and I have the same problem. I was using Castrol full synthetic 5-30 before but when the car was without acceleration at all (on neutral) I had a noise I did not like (like the valves). I really do not know what to do about the oil and I have to change it very soon. Could someone give me an advice? Perhaps it’s not the oil…
Mar 11, 2006 at 10:38 AM
PEPPERMRJ
  • 1,158 POSTS
Hmmm. I assume that the noise is from the engine compartment. it sounds like detonation, engine knock, pinging, whatever you want to call it. I would have the knock sensor checked.
I doubt that oil would have much to do with it.
Good luck and let us know. :)
Mar 11, 2006 at 2:19 PM
Suggested Repair
Have the knock sensor checked. The high-speed rattle under hard acceleration sounds like detonation or engine knock rather than an oil-viscosity problem.
Conversation Summary
A 2000 Ford Explorer Sport with a manual transmission and about 60,000 miles has a moderate rattle during hard highway acceleration and while cruising at about 65-70 mph or higher. The owner wondered whether oil weight was the cause after switching between Castrol full synthetic 5W-30 and 10W-30. The expert assumed the noise was from the engine compartment, described it as detonation, knock, or pinging, recommended checking the knock sensor, and doubted that the oil was responsible.
