1998 Explorer 151,00 miles - "ticking"
1998 ALL OTHER MAKES ALL OTHER MODELS
FLYNNKS
After recently changing the oil and checking for leaks I noticed a "ticking" sound coming from the bottom side of the engine. Could it be the water pump or oil pump? I have also noticed that the oil level is lower than what I put in last time, seems to loosing somewhere, but have not seen any signs of leaks in parking areas. I am I headed for a costly repair?
Jan 10, 2007 at 7:38 AM
SERVICE WRITER
  • 9,123 POSTS
Is it around the belt area in particular the serp belt tensioner?
OR is it a heavy metalic knock sound?
Jan 10, 2007 at 9:37 AM
FLYNNKS
Its a metalic sound but not heavy. At first I thought it may have been the water pump, then I thought it may be coming from thr oil pan area.
Jan 10, 2007 at 9:52 AM
SERVICE WRITER
  • 9,123 POSTS
Take a real long screwdriver or bar with a handle. Touch it to each component's housing and put your ear on the handle, using it as a stethescope. You'll hear where the roughness is and begin to isolate it.
Jan 10, 2007 at 9:55 AM
