Also is there a likelyhood that a car with this problem would keep a charge while driving for an hour so I can get to my normal mechanic or should I not chance it and get it fixed where I am?
1992 Chevrolet Lumina Won't Hold Charge
Backyardmechanic :)
Suggested Repair
Fully charge the battery, then measure voltage at the battery with the engine running. A normal reading is about 13.5 to 15.5 volts; outside that range, the alternator is likely defective and should be repaired or replaced.
Conversation Summary
The owner of a 1992 Chevrolet Lumina says the car made a ticking noise when starting, needed a boost, and will not restart after being shut off. The alternator looks fairly new, and they ask whether the battery is at fault, how to test the system, and whether it is safe to drive about an hour to their mechanic. The expert says the alternator is likely bad and recommends testing with a voltmeter only after the battery is fully charged: running voltage should be 13.5 to 15.5 volts, and a reading outside that range indicates a defective alternator.
