88 Corolla fx-124000 miles - knocking noise from the engine
NCCHETAN
MEMBER
ALL OTHER MAKES ALL OTHER MODELS
I was earlier not able to crank the car. After letting it sit for a couple of weeks I tried starting the car after putting in a Quart of motor oil, and it started just fine.
The engine sounds fine on low idling. If I hit the gas pedal (even in Neutral) I hear a continuos knocking sound from near (or from?) The engine.
Thursday, April 27th, 2006 AT 1:07 PM
LOSONE
MECHANIC
Is the knock from the top or bottom of the engine?
Monday, May 1st, 2006 AT 11:23 AM
NCCHETAN
MEMBER
It appears to be from the op of the engine.
Thanks for you reply.
Monday, May 1st, 2006 AT 6:53 PM
NCCHETAN
MEMBER
*top* of the engine
LOSONE
MECHANIC
A top engine knock may be associated with a timing belt about 1/2 tooth off. If the belt breaks it's goodby top of the engine. How long since the belt has been changed. The water pump is cam belt driven also and could be the noise. Let me know.
