1999 Ford Explorer Shift Positions Wrong
GRIMESLEE
I have a 1999 Ford Explorer XLT with an automatic transmission. When I move the shift lever to Drive it's really in neutral, and neutral is now reverse. What's wrong with my Explorer?
Mar 25, 2006 at 3:56 AM
LOVESCARS
  • 359 POSTS
The shifetr is normally cable operated you may need a new cable or just an adjustment
Mar 25, 2006 at 1:11 PM
Suggested Repair
The shifter is normally cable-operated. Adjust the shift cable, or replace it if adjustment does not restore the correct gear positions.
Conversation Summary
The owner of a 1999 Ford Explorer XLT automatic reports that selecting Drive actually puts the transmission in neutral, and selecting neutral puts it in reverse. The expert says the shifter is normally cable-operated and may need a new cable or an adjustment.
