2002 Ford Explorer Transmission drain plug
76,750 MILES • 6 CYL • 2WD • AUTOMATIC
MATTWILLIS
I want to be able to check the transmission fluid level only I do not know where the plug is.
Dec 28, 2007 at 6:36 AM
MERLIN2021
  • 17,250 POSTS
If you stand in front of the truck look to the back of the motor, near the firewall, to the left side, you will see a red handled dipstick, check the fluid with the engine warmed up, and in park, motor running.
Dec 28, 2007 at 8:56 AM
