1997 Ford Explorer Shifting and Idle Surge
BASSHOOK
Hello
Our explorer is not shifting right. It goes into 1st ok and from 1st to 2nd we have to take it up to 3500 rpm. If we shift it by using the shift lever it goes into 2nd as soon as we shift, We then have to put it into drive of course. Also we can make it shift from 1st to 2nd and also 3rd by letting up on the throttle.
The other thing that has happened exactly when this problem occured is, The truck now races at idle too 12 or 13 hundred rpm and then drops down to about 600 rpm. It does this every time were at a stop light or in idle. It does this continually.
1997 Ford Explorer, 5.0 liter V8 124,000 mles.
Thanks
:lol:
Jan 23, 2007 at 10:29 AM
2CARPRO JACK
  • 11,533 POSTS
Of course check the fluid level first. What trans is in it? If there is a vacuum modulator on the trans it could be the problem. A vacuum leak can make the idle surge and the throttle lifting you have to do for it to shift
Jan 24, 2007 at 1:30 AM
BASSHOOK
The 1997 Explorer never came with a modulator, I believe they only came with older bronco's 94 explorers.
Whatever is wrong with the shifting is related to the bad idle (races up and down) as it happened at exactly the same day and time.
Thanks
Basshook
Jan 24, 2007 at 9:16 AM
2CARPRO JACK
  • 11,533 POSTS
Is ther Check Engie light on? If so have it scanned.If not could be a slow IAC valve or a vacuum leak causing the erratic idle
Jan 25, 2007 at 1:27 AM
Suggested Repair
Check transmission fluid level first. If the check engine light is on, scan for codes. If not, suspect a slow IAC valve or a vacuum leak, which can cause both the surging idle and delayed shifts.
Conversation Summary
A 1997 Ford Explorer 5.0 with 124,000 miles shifts late from 1st to 2nd unless RPM is high, the lever is used, or the throttle is lifted, and the idle surges between about 600 and 1200-1300 rpm. Both issues started together. The expert advised checking fluid, scanning if the check engine light is on, and considering a slow IAC valve or vacuum leak. The owner noted this model does not use a vacuum modulator.
