1997 Ford Explorer Transmission Coolant Mix
HARMANKARDON35
  • 5 POSTS
My tranny died the other day, engine just spun-up on the highway and i lost momentum. Transmission repair shop said the fluid was contaminated with antifreeze. How could this have happened? Vehichle is 97 ford explorer 4.0L v6, 145,000 KM.
Thanks In advance
Nick.
Aug 14, 2006 at 9:40 AM
MIKEYBDMAN
  • 623 POSTS
[quote:08a757ff8f="harmankardon35"]My tranny died the other day, engine just spun-up on the highway and i lost momentum. Transmission repair shop said the fluid was contaminated with antifreeze. How could this have happened? Vehichle is 97 ford explorer 4.0L v6, 145,000 KM.
Thanks In advance
Nick.[/quote:08a757ff8f]
Your radiator cools not only your engine coolant, it cools the transmission fluid also. If your radiator goes bad internally, it can get radiator fluid in your transmission, and transmission fluid in your coolant. You are not only going to have to get the trans repaired, you will need to replace your radiator, and flush the engine to replace all of the fluid.
Aug 14, 2006 at 10:13 AM
HARMANKARDON35
  • 5 POSTS
funny thing is, it looks like the rad is fairly new (not original equipment anyway...)
Aug 14, 2006 at 11:03 AM
MIKEYBDMAN
  • 623 POSTS
[quote:ee7910adc6="harmankardon35"]funny thing is, it looks like the rad is fairly new (not original equipment anyway...)[/quote:ee7910adc6]
Maybe they had a radiator problem and had the radiator replaced. Mean while coolant had gotten into the tranny and they didnt know it. It took some time for the damage to be done.
In this case, the radiator you have may not be bad. I would disconnect the tranny fluid lines from the radiator and run the engine up to operating temperature. If no coolant leaks out of the open tranny line holes, then it may be ok. Most shops have the ability to pressurize your radiator system to check for leaks. This will accomplish the same test.
Aug 14, 2006 at 12:12 PM
Suggested Repair
Repair the transmission and flush all contaminated fluid. Because the radiator also cools the transmission, an internal radiator leak can mix coolant into the transmission fluid. Pressure-test the cooling system, or disconnect the transmission cooler lines and warm the engine to see whether coolant comes out. Replace the radiator if it leaks, even if it looks newer, since earlier contamination may already have damaged the transmission.
Conversation Summary
The owner of a 1997 Ford Explorer 4.0L reported a sudden loss of drive on the highway and a shop finding antifreeze in the transmission fluid. The expert explained that a failed internal radiator cooler can mix coolant and transmission fluid. Even if the radiator looks recently replaced, prior contamination may already have caused the damage. The recommended checks are to test the radiator cooler, replace it if leaking, repair the transmission, and flush the fluids.
